Daewoo G30E-3 Engine type G424
Does anyone know if this is a mitsi engine and if its just a different name Daewoo/Doosan use for the 4G64 engine.
  • Posted 7 Jan 2008 22:51
  • By Leon_W
  • Tyne & Wear, United Kingdom
4G6 engine are the same. /OHC/
see link
mitsubishi-motors.kiev.ua/Manuals/Engine/pwee9616/11A.pdf
  • Posted 1 May 2014 14:22
  • By geroj
  • joined 21 Feb'10 - 262 messages
  • Krivan, Slovakia
is the g424 engine fitted in this truck, BearsFan4Life?
When you say "the oil pump drive shaft seal", where are you expecting to find that seal? are you going to drop the pan to get to the oil pump drive shaft? The g424 has a oil pump drive off the timing belt, not off the valve's overhead cam.
Or are you talking about the hydraulic pump's drive shaft?
  • Posted 26 Apr 2014 06:44
  • Modified 26 Apr 2014 06:48 by poster
does anyone know if to replace the front main seal, Cam seal, Valve Shaft seal and Oil Pump drive shaft seal does the engine have to be fully removed from the forklift? it is a G30E S/n CX-05173
  • Posted 26 Apr 2014 01:03
  • By BearsFan4Life
  • joined 26 Apr'14 - 1 message
Leon, G424 is the Mitsi engine. The G430 is a GM 3.0 engine.
  • Posted 8 Jan 2008 01:44
  • By carl_v
  • joined 12 Oct'07 - 76 messages
