no start problem
unit will start with either
  • Posted 9 Feb 2015 14:09
  • By lake
  • joined 9 Feb'15 - 1 message
  • Wisconsin, United States
I am having the same problem. mines is LPG. I have replaced the fuel shut off valve. I just ordered a regulator.
Any idea what the vacuum should be on this engine. I did not check that. it has 12750hrs. vacuum lines look good. that's the trail I'm on.
vin7AM02652.
mine will run on LPG after it starts.
  • Posted 25 Jun 2019 22:57
  • By RonZ
  • joined 16 May'19 - 7 messages
  • Colorado, United States
yep a serial number might be helpful
but you have ruled out everything except fuel, being it will start and run on ether.
is this a gasoline or LPG powered truck?
  • Posted 9 Feb 2015 23:40
?serial number?
  • Posted 9 Feb 2015 22:07
Esie Cortez Esie Cortez
