Mitsubishi FB16CPNT year 2013
Hi
i need service manual or list errors for this truck.
Now i have - #61 and truck not function
Some one make help me?
Piotr
  • Posted 20 Jan 2015 16:56
  • Modified 20 Jan 2015 17:56 by poster
  • By piotr_b
  • joined 3 Jun'09 - 41 messages
  • mazowieckie, Poland
how you have solved the problem ?
  • Posted 17 Sep 2024 22:08
  • By PanChasnyk
  • joined 19 Jan'19 - 8 messages
  • Ukraine
Does the Logic Card need to be programmed?
  • Posted 28 Aug 2024 03:53
  • By Nathan_Lugo
  • joined 28 Aug'24 - 1 message
nathan lugo
not good :-(
  • Posted 22 Jan 2015 01:57
  • By piotr_b
pc program op laptop and connecting cable
  • Posted 22 Jan 2015 01:53
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
what is service tool for this truck?
  • Posted 22 Jan 2015 01:45
  • By piotr_b
i have send it
  • Posted 22 Jan 2015 01:17
  • By gc_d
Regards gc_d
maverickcross (at) tlen (dot) pl
  • Posted 22 Jan 2015 00:31
  • By piotr_b
3.38 Logic Card Initialize Failure (61)
Error code: 61
Situation Display: "61". All operations inhibited. Line and steering contactor OPEN.
Possible
cause
Setup Option Group 3 data not set, Setup Option Group 1 and 2 default data not set, faulty Setup Option data,
faulty logic unit.
Trigger of
the error
code
Setup Option data is in abnormal setting range. MC specification is set at #43 while CAN data is received from
input unit or output unit.
Checks
(1) Turn off power, then turn on power in Setup Option Group 3 setting
(2) Set Setup Option Group 3 data
Confirm that SUO #43 and 50 have been set up correctly and their combination
with output unit and input unit is correct
(3) Set Setup Option default data
(4) Turn on power
(5) With service tool, set Setup Option Group 3 data
(9) With service tool, set Setup Option Group 3 data
(6) With service tool, set Setup Option default data
(7) Disconnect battery plug
(8) Replace logic card of logic unit
(10) With service tool, set Setup Option default data
send mail , i send the manual
  • Posted 20 Jan 2015 18:48
  • By gc_d
Regards gc_d
Hangcha FLDCXT160
Unicarriers FHGE35T5S
VETTER Industrie GmbH
Hangcha FLDCXT160
