Intermittent stopping
I have a Nissan machine here Model# RPXT2W2G60NV Serial# 2W26-9310817
The issue I'm having is while running the machine around the warehouse it will intermittently just halt to complete stop and almost through you off the machine. I've never had it happen to me, but it happens to the warehouse workers running it overnight. When I bring the machine into the shop and bring up the codes in the display stored in the log book this is what I come up with.
227 on node 5
4263hrs #07
no can message 16
can bus KO trac
4263hrs #53
248 on node 2
4263hrs #04
no can message
This machine has a ZAPI controller but I do not have a hand held for it.
Any help with this or pointing me in the right direction would be greatly appreciated.
Thanks
  • Posted 8 Jan 2015 07:11
  • By darek_s
  • joined 17 Jan'13 - 27 messages
We ran into a similar problem and the culprit ended up being the electromagnetic brake.
  • Posted 22 Aug 2018 05:47
  • By cody_c
  • joined 22 Aug'18 - 5 messages
  • Utah, United States
Any insight on this issue? This machine has come back to haunt me 6 months later. Machine now has 5433 hrs and same codes/symptoms. I'm leaning towards wiring issues since I have swapped tiller head units and zapi COMBIAC1 units from a sister machine. Just curious if anyone has come across any known chaffing issues or problem areas to check first. Any help would be greatly appreciated.
Thanks
  • Posted 24 Jul 2015 04:58
  • By darek_s
F. Uchiyama
