7FBEU18 slow back tilt
I have a Toyota 3-wheeler 7FBEU18 with no codes and back tilt is very slow. All other function work great.
Any advise is appreciated.....
  • Posted 8 Jan 2015 07:09
  • By KTM_Dude
  • joined 17 Jul'14 - 4 messages
Hey ToymasterTech, can you please post your email in profile or reply to mine?
Have a 7FGCU35 diverter valve question.
Thanks
  • Posted 28 Jan 2015 13:09
  • By EasiTek
Initially I'd check the tilt lock solenoid wires to see if there cut or damaged. Then do Matching properly. Check the tilt Potentiometer on the RH cylinder, see if it's intact. Also verify the micro switch on the top of the CV linkage is making contact or closing causing the pump to kick on. most likey the problem.(under the dash RH side)
  • Posted 28 Jan 2015 11:01
  • By ToyMasterTech
  • joined 27 Jan'15 - 13 messages
  • Maryland, United States
If it tilt is a mechanical lever style. Check the hydraulic control valve for loose hardware or components. If it's a fingertip control you can adjust speed through the dash ( Need qualified tech to make changes)
  • Posted 10 Jan 2015 00:49
  • By Prentice
Deborah Baker Deborah Baker
Muncie, IN, United States
