steering goes tight
Hi all I have a heli HFB 15 2004..4 wheel zapi
Problem being the truck will get intermittent tight steering
When operating the steering the pump does change note...when the steering goes tight the pump note sounds the same as when under normal load..it's a very simple system but I must admit this problem is giving me a headache..
Is there any pressure points that the pump pressure or orbital can be checked..iv checked king pins and steering ram and links all fine..
Any advice greatly appreciated
  • Posted 13 Dec 2014 05:09
  • By helta
  • joined 13 Dec'14 - 2 messages
  • leicestershire, United Kingdom
Mostly the Orbitrol under the steering has issues, if repairable please repair or replace the Orbitrol and your problem should be sorted out
  • Posted 13 Apr 2017 16:41
  • Modified 13 Apr 2017 16:41 by poster
  • By atulkumar_j
  • joined 20 Sep'12 - 3 messages
  • Gujarat, India
Atul Arvind Joshi
+971 56 4278842
joshishj@gmail.com
Skype:joshiatul1
Terberg RT223
Unicarriers FHGE35T5S
Kai von Berg Kai von Berg
Lift Tek Elecar
