new full charged battery only last 6 hour
Need some help. New fully charged battery only last 6 hour. Had battery and charger check. Test ok. Any idea will help. Also reach cylinder bang when retrack on another truck same model.
  • Posted 12 Dec 2014 12:32
  • By raj_h
  • joined 24 Apr'14 - 9 messages
thank you ray tech for your help.
  • Posted 15 Dec 2014 04:00
  • By raj_h
You dont mention what voltage. 36 volt can last 8 hrs, not a 24 volt truck. A/C motor lasts longer, DC eats more battery time. Type of battery makes difference. I've seen a load of batteries arrive new, same type and volatage. Some will never last 8 hr shift and always give shorter work times. 6 hours might be normal if the truck is run non-stop. If you have two trucks the same, are the results similar with battery in each truck? Or different batteries? If not, ask for warrantee on the new battery.
For reach cylinders, the old Easi reaches always hit hard. Make sure the bumpers are in place and each cyl is adjusted evenly. Setting the reach to 2-speed can help. With 2 speed, You need to push both buttons one after the other to get fast reach or retract. Letting go one button slows the retract down so the banging and load shifting is not so hard. You need access to Superword to change settings and must know the code for Superword
  • Posted 14 Dec 2014 09:07
  • By EasiTek
Toyota 8FGCU25
Flesherton, Ontario, Canada
SMV (Konecranes) 4632CC5
Omaha, NE, United States
edition #1249 - 25 September 2025
The US Monthly Confidence Index, measuring the mood of the equipment finance industry, has remained stable for the fourth consecutive month, despite one survey respondent saying “competing economic forces and political strategy collide to create an unusual operating environment”. Read the full story in this week’s news ... Continue reading
Jeannette Walker Jeannette Walker
Vice president, customer, TVH Americas
Chief executive officer, Seegrid
Chief commercial officer, Meijer Group
Chief executive officer, Hire Industry Association New Zealand (HIANZ)
