no start without ether 2005/6 mitsubishi
new plugs, wires, cap, rotor, vaporizer assembly, cleaned carb , and all lines, had a waxed fuel system, will only start with ether, runs good in neutral after starting, some idle search afterwards, code 522655-1 on dash, truck has been major head ache and expensive please help
  • Posted 26 Nov 2014 10:14
  • By dave2009
  • joined 19 Aug'14 - 4 messages
  • Michigan, United States
by the date code in the serial number, this should have a trim injector mounted in the base of the carb. You may need to change the trim injector.
  • Posted 9 Dec 2014 08:59
  • By BREWSKI
was running good with acceleration now seems it doesn't want to,
truck is a s50t hyster with a mazda engine serial # F187V05761D
sorry about the mix up, have a fleet of 12 some times mix them up
  • Posted 6 Dec 2014 09:57
  • Modified 6 Dec 2014 10:00 by poster
  • By dave2009
You say the truck runs good at idle when started,how does it run when you give it gas........how about when you rev it up and put it in till bypass and put a load on the engine????
  • Posted 26 Nov 2014 14:31
  • By kevin_t
What is the FULL make,model and serial number of the truck.....thread description says 2005/6 Mits but is listed under Hyster thread.....need clarification..........
  • Posted 26 Nov 2014 10:23
  • By kevin_t
