Error Code 828
I'm having a little problem with one of our stock pickers. One of the driver was telling me that when the tried driving it the wrench light came on and the truck would drive very slow until they reset it. I drove it around the building and had no problems. So I looked up the event codes and got a 828. I have no idea what his code is. If someone knows will you please let me know? Thank you for your time.
-Michelle
  • Posted 25 Nov 2014 02:24
  • By michelle_p
  • joined 25 Nov'14 - 2 messages
  • Kansas, United States
Thank you very much. This helped a lot.
  • Posted 26 Nov 2014 03:28
  • By michelle_p
828 is height encoder (ECR4) and/or height switch reset fail. Basically the reset switch didnt trip or it tripped at a point when the counts on the height encoder were off from where it should be. I have found this happens a lot when an operator travels a long an isle picking going up and down but not going all the way down to "reset." After the extended time, ECR4 end up with the counts off and creates the fault. Most commonly lowering all the way to ground then lifting platform above reset (about 4' to 6' off the ground) then back down resets the counts/fault and full speed travel will be resored. If this does not work or if the fault continues to come up you will want to test your reset switch and or your height encoder. If you have the cable style ECR4... Have fun! These cables are common for breaking but are pretty easy to replace. Just be careful!!! The preloaded coil spring inside there cand tear you up like a mountain lion! about 50X what a 30' tape measure does. I had one get away from me one time years ago... Not fun!
  • Posted 26 Nov 2014 02:33
  • Modified 26 Nov 2014 02:37 by poster
  • By chevotaman
  • joined 28 Feb'14 - 112 messages
It's all just nuts n' bolts.
a correct model and serial number will help us give better opinions.
  • Posted 25 Nov 2014 11:25
Davenport, IA, United States
Philadelphia, United States
Prospect CT, United States
Dayton OH/Cincinnati OH, United States
Toyota 02-8FD30
Taylor TX175
New - Sale & Hire
edition #1251 - 9 October 2025
