warning light flush 4 times,
Truck start fine. but does not move or lift. the warning light flush 4 times when you try to drive it. please advise the problem.
  • Posted 22 Nov 2014 14:14
  • By li_w
  • joined 16 Nov'09 - 49 messages
seat switch not working test
  • Posted 26 Jan 2020 06:13
  • By Firerescue
  • joined 25 Jan'20 - 9 messages
  • New Zealand
Bryan
We Have the same issue.
The exclamation point flashes 4 times ,the forks steadily flashes.
Keeps blowing fuse.
Where might I find the lockout solenoids?
  • Posted 13 Aug 2017 06:02
  • By Mightyduc
  • joined 13 Aug'17 - 1 message
Per komatsu check mast, forward or reverse relays. Abnormal outputs. Also check all fuses. I think main aux. fuse will cause this also. If it continues to blow that fuse, check lift / tilt lock out solenoids
  • Posted 25 Nov 2014 07:51
  • By stanley_c
  • joined 25 Nov'14 - 1 message
UN Forklift FBRS15KQZ2
Hangcha FLDCXT160
ROYPOW
Hangcha FLDCXT160
