loosing ignition voltage
good morning guys. this toyota lift is loosing ignition voltage to the lp converter. voltage is present when key switch is in start postion but looses it after engine starts and key is in the run postion.i checked the switch and voltage is still there but when the starter relay drops out i loose voltage. any hints? thanks Jim
  • Posted 10 Oct 2014 03:42
  • By Hystertech3160
  • joined 4 Mar'14 - 26 messages
  • Arkansas, United States
thanks.got it figured out. shorted tack wire to shield.
  • Posted 10 Oct 2014 06:01
  • By Hystertech3160
Check the relays under the Fuse assembly - Under left step up plate
  • Posted 10 Oct 2014 04:26
  • By Prentice
Nagano NUL120-6
Taylor TT300
Nagano NUL120-6
Taylor TT300
