oil leak
I'm looking for an oil leak. I replaced the front crank seal twice and it is still leaking around that same area. Does anyone know if there is an area where it might be leaking where it looks like a crank seal?
  • Posted 5 Oct 2014 01:52
  • By tilo_g
  • joined 5 Oct'14 - 2 messages
there is also a seal behind the oil pump gear, and the oil from the valve cover gasket can run down that way, in behind the timing belt covers.
  • Posted 5 Oct 2014 03:01
