codes a30 66
fault codes. 66 A30. -15. not operate forklift traction.
MODEL TMG15S TMG248.
someone help me with leaf codes thanks.
  • Posted 9 Sep 2014 06:09
  • By minion
  • joined 9 Sep'14 - 2 messages
  • juarez, Mexico
Do what you can, with what you have, where you are.
Ok thanks for telling me about code30 now that I've solved how do I reset engine error light
  • Posted 30 Oct 2014 06:54
  • By ktutt01
  • joined 30 Oct'14 - 1 message
The 66 is one of the traction boxes is sensing a field fault (normally a bad controller) The 30 is due to the signal from the slave controller to the master traction controller is under 5 volts. This signal is from pin 10 of the slave to pin 21 of the master.
  • Posted 10 Sep 2014 09:32
  • By JimConnected
  • joined 23 Jun'11 - 15 messages
thanks for the support. kevin
  • Posted 9 Sep 2014 06:37
  • By minion
  • juarez, Mexico
Not sure what the 66 and A30 are but the -15 is a code for the battery voltage to low(less than 1.95 volts per cell) charge the battery or swap with a know good battery and see of it goes away,load test the battery and do a specific gravity test on all the cells.....check the charger operation and make sure the charger is functioning PROPERLY
  • Posted 9 Sep 2014 06:20
  • By kevin_t
Toyota 02-8FD30
UN Forklift FD20-35FJM3
Toyota 02-8FD30
