Best Method to bleed brakes
c500-40. I have read through the forum on brake bleeding. I'm finishing a complete brake job (shoes, wheel cly, both master cyl). I don't have a power bleeder, but I do have a hand vacuum pump. I noticed some discussion on master cyl location (horizontal v vertical) mine are horizontal on each side of the engine.
Can I use a vacuum pump and pull the fluid from the reservoir?
I read about using a "squirt" type oil can with a piece of tube and pushing back to the master cyl.
Does the Master cyl have to be bench bled prior to installation?
  • Posted 21 Aug 2014 23:01
  • By duane_c
  • joined 6 Aug'14 - 31 messages
Bench bleeding the mc cuts down on the time it takes to bleed the system. I've personally never had luck with the pressure/vacuum bleeders on the market. It's easy enough to bleed by pressing the brake pedal by hand & bleeding the several bleeders in the system.
  • Posted 21 Aug 2014 23:07
  • By bbforks
SMV (Konecranes) 16-1200B
Taylor TX330S
USD159,500
edition #1257 - 20 November 2025
Taylor TX330S
USD159,500
Oxford Ct, United States
