Please if any one can help me i have aproblem with a junghiernich fork lift model efg-fd16 it gave me error 18 controller &thanks alot in advanced :D
For DC motors, same thing as AC, armature or cables.
Yes It means also to check motor armature cables and electronic unit,somewhere on that part you have problem.
Thanks mrfixit but by the way the forklift is dc motor??
I'm just reading the list of codes and it says for AC powered trucks that one of the 3 phases can not be switched on and to check wires to motor and then replace power part, replace component. I think that means the problem is in the motor or cables. Hopefully someone more familiar with Jungheinrich will chime in.
Thanxs alot mr fixit for your reply & is this problem from also the inverter which deliver the power to the armature or not ??
error 18 Armature can not be switched on. Check armature wire connections and motor armature.
Can any one offer me a help in this problem or what parts should i check it ??
