no forward/reverse DP30 1993
bought this second hand unit forklift months ago. at first, it was doing very good/ operates smoothly. but suddenly it stopped moving forward or backward. one of our friend technician suggested to have its' solenoid changed so we did. but it didn't work.
  • Posted 30 May 2014 00:02
  • By donnabel_n
  • joined 29 May'14 - 3 messages
  • rizal, Philippines
good suggestion nick
he also may want to check the transmission fuse in the fuse block
in the DP30 manual they call it a direction solenoid fuse, pull the fuse cover off at the steering column and check the first one at the top
  • Posted 11 Jun 2014 14:10
is there any voltage from the forward\reverse switch going to the solenoid ?
  • Posted 11 Jun 2014 11:45
  • By Nickauger
  • joined 11 Jun'14 - 9 messages
  • Quebec, Canada
stii the unit doesnt move. filters were checked and the pressure. what could be....
  • Posted 10 Jun 2014 11:39
  • By donnabel_n
thank you. I'll do that. serial number 7BP00278
  • Posted 30 May 2014 09:27
  • By donnabel_n
first i would pull the sump screen out from the base housing and see if it is stopped up, clean it up and reinstall.
secondly there is a strainer in the control valve that should be checked and replaced if clogged up.
I'm not sure on this particular model without a serial number but some of them had port screens between the control valve and the base mount (top of transmission), there were 2 of them that sometimes would clog up also.
also you might want to check the fwd/rev clutch and pump pressures
  • Posted 30 May 2014 02:54
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
Taylor TX330S
USD159,500
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
