no display after start up after 4 years Jungheinrich ETX-K150 1998
Hi all, Have a problem with a ETX. Truck start up but no tekst on display, led of the service on. no functions
  • Posted 3 May 2014 02:56
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
if green light led in box under seat and in rear ok then can system is ok just incase try pressing the left or right arrow button several times this increases display backlight on display or if it is just display light truck should still function ok
  • Posted 12 May 2014 07:13
  • By trevb
  • joined 10 Jan'12 - 157 messages
  • avon, United Kingdom
Thanks elektrodrive,that is good advice and It could be
possible for that reason I was write our colegue to check display.I think that must start without display in slow mode.
  • Posted 11 May 2014 07:32
  • By nemanja_k
  • serbia, Serbia
Hi
Have you considered the possibility of the lcd failing in the display unit? Its known to happen on the efg trucks when water ingress occurs.
  • Posted 10 May 2014 18:55
  • By elektrodrive
enquiries@elektrodrive.co.uk
HI , i have a new full battery , wiring oke. display give light but no letters on it. the voltage on the control boxes and prints are oke.
the leds on the print in the cabin and in the aluminium box on the top of battery are green so it is oke.
  • Posted 8 May 2014 04:01
  • By gc_d
Regards gc_d
Maybe,but it could be also some bad conection or low voltage,or no voltage on some pin.Did you check battery wiring controllers and is it something strange?Maybe is problem in display,do you try without him to start truck?
Do you have lite on display without letters or is display totaly black?Please write me what did you see
  • Posted 7 May 2014 09:09
  • By nemanja_k
  • serbia, Serbia
hi ,the serialnumber is 794812401 and year 1998 to 1999. i think there is no data in truck? eeprom empthy or something?
  • Posted 4 May 2014 16:25
  • By gc_d
Regards gc_d
Hello mate
That is hard forklift,you are check fuses and dc-dc converter?Can you give more data from vehicle and to we try together.
  • Posted 4 May 2014 06:46
  • By nemanja_k
  • serbia, Serbia
Load Lifter LLL6000
Flesherton, Ontario, Canada
Terberg RT403
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
F. Uchiyama
