Nissan APH0225V stalls engine on back tilt.
This truck stalls engine when fully tilted back. There is a relief valve on the tilt section of the control valve which is supposed to limit the pressure on back tilt to 1350 PSI so I'm told. The pressure is about 2700PSI and doesn't change at all with adjusting the relief. The pressure does change by adjusting the relief valve for forward tilt though.
We have swapped the tilt pressure relief valve from a know good truck that doesn't stall and it didn't change anything.
Any thoughts. I am in a pickle because I have to deliver the truck tomorrow morning.
  • Posted 18 Apr 2014 07:14
  • By duodeluxe
  • United States
duodeluxe
The pressure for your lift valve and tilt valve are one in the same. Your main pressure relief for these two is usually right above the input for the hyd fluid. The other valves that have adjusters are for each function that needs to be reduced from the high pressure.
I just had one of my mechanics in the field with the same problem on the same Nissan I believe and I just had him adjust the timing to give it a little more power and to lean it a little. It worked for him, sometimes it is a worn engine without compression but most of the time it is cured by adjustment. 2300lb hyd pressure is fine and is not the problem. Check the pot as Mr Fixit stated if it has a kick otherwise clean and adjust the carb or time. Good Luck
  • Posted 18 Apr 2014 12:48
  • By ForkMob1
  • joined 18 Apr'14 - 1 message
"TO HELP OR BE HELPED, THAT IS THE QUESTION."
Larry@ForkliftMobile.com
I am with mrfixit as the forward tilt pressure is lower than back tilt. as mrfixit stated, check your dash pot!
  • Posted 18 Apr 2014 12:44
  • By RCAV8TOR
  • Alabama, United States
Is the dash pot on the carb working ok and kicking the throttle open when the motor is strained?
  • Posted 18 Apr 2014 09:01
Sorry, it is an APH02-25V
  • Posted 18 Apr 2014 07:15
  • By duodeluxe
  • United States
duodeluxe
Taylor TX175
New - Sale & Hire
Hangcha CBD15
China
USD1,600
Lift Tek Elecar
Tacoma, WA, United States
Highland, IL, United States
Orlando area, United States
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
Bobcat appoints new UK dealer Liverpool, United Kingdom
Lift Tek Elecar
