error code
customer has a 8FGCU15 with an intermittent shut off - no restart
showing an error code of ES-9 or E5-9
any help would be appreciated
  • Posted 10 Apr 2014 03:31
  • By 67Malibu
  • joined 20 Feb'14 - 18 messages
  • Oklahoma, United States
I'll definitely look at those possibilities! Thank you so much!
  • Posted 4 Jun 2014 08:24
  • By paul10
  • joined 18 May'12 - 15 messages
FO-2 - EHPS Abnormality
Current flow in motor although TMPS is NOT on. Basically the unit is seeing current flow through the steer motor without the unit actually being on.
There is a fault somewhere in your steering system. There are numerous possibilities. Things to check:
Battery voltage
Key switch
Check the power steering wiring
The other checks require opening the PS Controller. Only a skilled technician should attempt it. 36/48 Volt forklifts are dangerous and severe shock can occur. Checking for voltage on wrong terminals can also fry your multi meter as well as the main forklift controller. Hope this helps...
  • Posted 4 Jun 2014 07:02
  • By LTS1
  • joined 18 Dec'13 - 74 messages
can you tell me what the code fo-2 is onf a 7fbcu25?
  • Posted 4 Jun 2014 02:38
  • By paul10
Neither of the codes you have provided are legit. Please check code again and reply.
  • Posted 14 Apr 2014 10:11
  • By LTS1
edition #1251 - 9 October 2025
Philadelphia, United States
Prospect CT, United States
Dayton OH/Cincinnati OH, United States
Davenport, IA, United States
Noblelift
Todd J Doxsee Todd J Doxsee
Sales operations, Heli
Chief financial officer, Cyngn
Executive vice president and chief commercial officer, East Penn Manufacturing
Noblelift
