code 135-2
Hyster S120FTPRS S/N G004V02952E intermittenly no starts throws code 135-2, smell of propane. Suspect lp regulator bypassing. Don't have diagnostic connections. Any help appreciated. Thanks
  • Posted 2 Apr 2014 07:25
  • By catmech518
  • joined 2 Apr'14 - 2 messages
feild tech
A. GROUND OPEN CIRCUIT
B. SENSOR SIGNAL OPEN CIRCUIT FAP, (HYDRAULIC PRESSURE AND MAZDA/2011 GM OIL
PRESSURE ONLY)
C. SENSOR SIGNAL SHORTED TO SENSOR SUPPLY
D. SENSOR SIGNAL SHORTED TO BATTERY
E. SENSOR FAILURE
F. FUNCTIONAL FAILURE IN CONTROLLER
  • Posted 9 Feb 2019 00:23
  • By BREWSKI
What is the 135-3 code? Have a Hyster S120FT, serial number G004V02259E
It's throwing the 135-3 code
Randomly shuts off and you can fire it right back up. May run for 2 min or may run 30 min not set time for when it shuts off. We currently don't own any books on the lift so have no idea what the code is, any help?
  • Posted 9 Feb 2019 00:00
  • By tanner_k
  • joined 8 Feb'19 - 1 message
  • Mississippi, United States
Not sure , customer said that was code. Customer said they would recheck code when it came up again. It more that likely is 135-3.
Thanks John
  • Posted 3 Apr 2014 01:41
  • By catmech518
feild tech
you sure about that code? there is no 135-2 code in the DTC chart.
there is a 135-3 that deals with the Fuel Air Pressure OORH (GM LPG engines only)
and a 135-4 same thing
no 135-2's tho
  • Posted 3 Apr 2014 01:25
  • Modified 3 Apr 2014 01:25 by poster
Toyota 02-2TD20
Aichi SR18A
Yale Lift Truck Technologies
