Water Pump Leak
I have water that is leaking out the back of my forklift. I believe it may be the water pump. Can anyone let me know how involved the replacement is. Does the counter weight need to be removed? Any advice would be appreciated.
  • Posted 2 Apr 2014 01:52
  • By mdsulli
  • joined 2 Apr'14 - 1 message
I think that's a Hercules motor. You don't have to remove the counterweight. It's not one of the easier ones. One thing I've noticed is the new pumps have a thicker area on the side/edge of the cast housing that doesn't let the pump sit down tight on the block because it interferes with a bracket or something on the front of the block also. You have to take a grinder and take a little metal off there. Hold the new pump in place and you will see what I mean, it just barely interferes. I don't know what's up with that, but the ones I've done have had that problem with the new pumps (Cats and Daewoo)
  • Posted 2 Apr 2014 07:52
Terberg YT220
Ncn 110TH
Ncn 110TH 2015
Terberg YT220
Ncn 110TH
Ncn 110TH 2015
