toyota EO code
Toyota 5FBC15 SN 11478
Just had the cpu repaired at Unipart's, I'm now getting EO code.
the alarm is continuous with key switch on or off it still continuous alarm. no lift. So if problem is in lift circuit does the alarm continually sound.
  • Posted 29 Mar 2014 02:18
  • By Parkway
  • joined 21 Jan'10 - 83 messages
pkwyls AT verizon DOT net
look after the diode's in the center of the controller.
  • Posted 21 Apr 2014 16:17
  • By johngen
  • NB, Netherlands
Found ground to frame, lift motor power cable was shorting to frame so repaired cables and replaced transistors. lift worked a few times, tilt worked a few times and when I pulled the sideshift "Pop" code EO!! there goes new transistors. any idea what's going on would be helpful Thanks
  • Posted 17 Apr 2014 23:57
  • By Parkway
Hello Mate
from a FBE (same system) the code is:
Material handling transistor open short.
I should have some info on how to test it
Not sure about the sound cos i've not had that fault
  • Posted 29 Mar 2014 05:39
  • By fred_t
  • joined 27 Feb'14 - 15 messages
  • london, United Kingdom
Toyota 8FBE20U
Flesherton, Ontario, Canada
Hangcha CBD15
China
USD1,600
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
Toyota 8FBE20U
Hangcha CBD15
China
USD1,600
Tacoma, WA, United States
Orlando area, United States
Highland, IL, United States
Board member, UKMHA
