code 15
Have a micro command II system 2ec30 cat with regen with a intermitten code 15. Problem happens when the truck gets warm and you go full throttle, cuts out when you hear the high speed contactor pull in, and codes out, let machine cool, works fine till gets warm again. Tried another battery, problem still persists, and input? Thanks in advance.
  • Posted 27 Mar 2014 03:57
  • Modified 27 Mar 2014 03:58 by poster
  • By patrick_b
  • joined 10 Dec'11 - 30 messages
  • Alberta, Canada
ROYPOW
Oxford Ct, United States
