Komatsu error E27
help! forklift komatsu dislay error E27
  • Posted 19 Mar 2014 00:08
  • By nguyen_s
  • joined 5 Mar'14 - 66 messages
  • binh tan, Viet Nam
thanks i check ok
  • Posted 21 Mar 2014 21:59
  • By nguyen_s
my reply to you assumes you have a komatsu with a Nissan k-21 engine, if not disregard
  • Posted 20 Mar 2014 23:45
  • By jeremy_s
  • joined 28 Mar'08 - 205 messages
thanks, i will check
  • Posted 20 Mar 2014 22:57
  • By nguyen_s
E27 = output of travel moter temparature is defective.
  • Posted 20 Mar 2014 03:39
  • By songyot_v
  • joined 8 Jul'11 - 103 messages
  • Thailand
thanks
komatsu fb25ex-11
  • Posted 19 Mar 2014 23:15
  • By nguyen_s
Spark plugs, maybe a coil pack? E 27 is a crank position sensor error, the ECM is looking for crankshaft speed to increase every time it fires a plug, if it does not see this increase it will throw a code 27, which is usually due to wide plug gaps. This applies only if the unit is running if not, it is crank sensor or wiring.
  • Posted 19 Mar 2014 07:43
  • By jeremy_s
hi nguyen s.
what is model.
  • Posted 19 Mar 2014 01:24
  • By songyot_v
  • Thailand
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
