ignition
Hello everyone. I have a nissan cpf02a25v with a serial number of 026804. I am looking for info on the ignition system. Mainly point gap and ignition timing. Any info would be appreciated.
Thanks
  • Posted 14 Mar 2014 03:54
  • By shaner
  • joined 1 Mar'11 - 29 messages
  • British Columbia, Canada
being this is an fo2 truck and is almost not a fossil, i would consider checking the distributor shaft for wear. There are a many of these trucks running amuck that are in dire need for new distributors and the point gap can be real tricky to set. If your distributor has no side play you can probably get by with.018 gap. Plugs i would set.035. If you have dist play then pack a lunch and i hope you have plenty of patience.
  • Posted 25 Mar 2014 13:15
  • Modified 25 Mar 2014 13:16 by poster
  • By RCAV8TOR
  • Alabama, United States
the unit runs on propane
  • By shaner
