Mits EOP15
...I have a Mits EOP serial# 1eop240602. I keep getting errors 43 and 57, which are both current sensor errors. The ev100 scr plate was damaged by a user forking the side of it, I was able to get it up and running by replacing a rec and some snubbers...The truck ran fine for 6 mos, now the errors came back. I replaced the whole entire scr plate and I'm still getting these intermitent errors...I'm stumped..any input is greatly appreciated!!
  • Posted 4 Mar 2014 10:35
  • By ctforkliftguy
  • joined 14 Mar'13 - 48 messages
  • Connecticut, United States
status code -06
Throttle advanced with no direction selected
this could be slow directional contactors or bad directional switches (don't think this unit has directional switches)
could be a flaky pot in the control handle (might want to try a relearn on the travel pot)
Also check the circuit between the control card and the contactors, TB5(fwd) and TB6(Rev) and TB1(accel)
Check the carriage wiring board connections between it and the accel control handle.
  • Posted 5 Mar 2014 22:29
...after speaking with the operator, he claims he has also seen an -06 pop up as well!!...so the plot thickens!!
  • Posted 5 Mar 2014 21:52
  • By ctforkliftguy
the amp draw should not exceed the rated amperage on the drive fuse which i think is 350A. I doubt this is the issue as you would have to put the motor in a dead stall to get it even close to that amp draw. But it never hurts to check these things.
  • Posted 5 Mar 2014 15:19
  • Modified 5 Mar 2014 15:29 by poster
..Swoop...as always..thank you for your input! Yes, a entirely new panel and ev100 card.....I will have to check the amperage draw if I can tommorrow. I checked evrything in the card today and matched it with another truck just like it and the settings are all the same...Funny thing is, the truck can sit for a while and then you can use it for about 10 min before the code pops up
  • Posted 5 Mar 2014 12:46
  • By ctforkliftguy
entire panel eh?
new control card too? (i'll assume yes)
then yes check the motor and cables
if you have an amp meter capable of measuring at least 600 amps i would check the amp draw on the drive system too and see if it is within specs for this machine. If it's drawing an excessive amount of amps it may trigger this code.
  • Posted 5 Mar 2014 00:05
Hi Swoop...The entire panel has been replaced with all new wiring on it. PZ4 and PZ3 are brand new into the EV100 plug...I verified there position with another truck. The operator states it only happens after about 10 minutes of use....I'm wondering if it may need brushes?
  • Posted 4 Mar 2014 21:58
  • By ctforkliftguy
was there any wiring on the panel that may have gotten damaged from the impact?
have you insured you have the polarity correct on PZ4 and PZ3 wires?
All connections are tight?
do you have another unit you can swap out the card with and see if it goes away?
  • Posted 4 Mar 2014 15:08
Tacoma, WA, United States
Dallas, TX or Lexington, KY, United States
Orlando area, United States
Highland, IL, United States
TCM FD115-3
UN Forklift FB25N1QZ1
