let me see if I can obtain a part number. When I replace them I do one side at a time, remove a tire, remove a bushing cap, jack up the mast rail, use a come along to pull the mast forward, slide the old bushing off, slide a new bushing on, release the come along tension, lower the jack, install the cap, and reinstall the tire, it takes about 20 minutes per side this way.
Hi, Yes the mast pivot pin bushings are one of the repairs we need to carry out. haven't stripped it yet to see if it's the bushes and pins, but would assume so.
Mast pivot pin bushings? If so I may be able to acquire a part number.
