(YALE) Jungheinrich EFG-V 40 AK
Hi all I have a Jungheinrich EFG-V 40 AK G183 360ZT S/N 5003A00206T YOM1996 (Yale type)
With sevcon hydraulic control.Intermittently we lose the hydraulic, all functions. Contactor closes but no pulsing. Any thoughts on possible cause or tests would be greatly appreciated.
  • Posted 26 Feb 2014 18:04
  • By nick_c
  • joined 17 Jun'11 - 116 messages
  • south glos, United Kingdom
Thanks for that Nero will try as you suggest. Nick
  • Posted 28 Feb 2014 00:02
  • By nick_c
I'm just thinking is the hydraulic unit on its own heat sink plate about six inches by six and can you see the thyristors, I'm trying to visualize this unit from years ago, I think it might be the sevcon unit that has gone down, The one I removed from a truck back in the nineties I took to Sevcon in team valley Gateshead, it turned out to be faulty but they where amazed at its performance it had done over twenty five thousand hours before failing. You could phone them and give them the serial no of the unit' and I'm sure there technical department will tell you how to check it out, they were always very helpfully when I took them units, the hydraulic contractor if it is an allbright single pole contractor check to see if it is closed properly sometimes they look closed but their stuck open slightly. The thyristors are quite large and will have a 2volt gate signal to fire them. I hope some of my comments are usfull as I'm guessing at this.
  • Posted 27 Feb 2014 23:38
  • By NER045
Hi Nero yes it's circa 1996 with GE traction control
  • Posted 27 Feb 2014 06:54
  • By nick_c
Nick, is this quite an old truck it's the AK that makes me think it is.
Nero
  • Posted 26 Feb 2014 20:41
  • By NER045
SMV (Konecranes) SL28-1200B
JLG 260MRT
JLG 260MRT 2016
Flesherton, Ontario, Canada
Highland, IL, United States
Dallas, TX or Lexington, KY, United States
Orlando area, United States
Tacoma, WA, United States
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
