ETV216 91010601
I have a problem with a jungheinrich ETV216 91010601.Every hydraulic moovement we try the truck lifts the fork. I mean that when i use the tilt lever the truck lifts, same with the rest of levers.Any ideas?
  • Posted 21 Feb 2014 00:31
  • By tasos_t
  • joined 20 Jul'13 - 259 messages
  • ATTICA, Greece
Hi Tassos
Ive seen this problem before on the Etv the problem is in the hydraulic control valve in the reach carriage the lift spool will be stuck you can try and strip and clen it out you do this by removing the solenoid valves but by experience i know you will need to replace the complete control valve. It is critical on the Etv that the hydraulic oil is changed every 2000 hours. You will need to call in your local jungheinrich tech to teach in the valve block it will possibly work but you need to plug in a laptop to input the number on the valve block into the controller.
Hope this helps
  • Posted 22 Feb 2014 05:51
  • By lifter01
  • joined 4 Jul'09 - 461 messages
I'm not too familiar with these machines but try disconnecting the plugs from the lift section solenoid valves. If problem still exists it is likely internal in valve block. If this stops it then either a back feed to solenoid a or faulty lever pot.
Hopefully someone with more experience of these machines can help further.
Regards, Simon
  • Posted 21 Feb 2014 03:35
  • By simon_k
  • joined 31 Oct'04 - 147 messages
  • Devon, United Kingdom
Bobcat appoints new UK dealer Liverpool, United Kingdom
Combilift Ltd
Tacoma, WA, United States
Orlando area, United States
Highland, IL, United States
Dallas, TX or Lexington, KY, United States
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
