Code 18
What does the code mean? Truck has a steering problem, seems to be it won't stay on center almost like it is hunting for a wire though it doesn't have guidance on it. Truck s/n 2LL03946. Also, have tried several codes but can not get into truck to run learn. Any ideas on codes to try? The truck is built by Raymond and we have a lot of Raymond experience, but we do not have a manual for this truck and our Ray books do not show a code 18. Thank you for any help.
  • Posted 20 Feb 2014 05:23
  • By Rodey
  • joined 16 Oct'12 - 21 messages
  • Michigan, United States
code 18
Deadman Error
Reason: Deadman state descrepancies between Trucktracker steer controller and Vehicle Manager
Corrective actions:
- check connections between JS9-6 and J2-4
- check connections between JS9-1 and J1-3
- Replace steer controller
- Replace Vehicle Manager
I would make sure the deadman pedal switch is operating correctly, then if there are any safety arm switches (if it has safety arms on the sides of the platform) make sure they are working properly. This may not be it but you should make sure the TM and TT are getting the deadman signal from the pedal.
  • Posted 20 Feb 2014 23:02
  • Modified 20 Feb 2014 23:06 by poster
Oxford Ct, United States
Aichi SR10C1SM
UN Forklift FD50T-NJB3
Hyster
Esie Cortez Esie Cortez
