Jungheinrich EFG216
Hi
Forklift sudden stops and the brake pedal is pressed on the gas again does not work. To run again for 5 minutes to cut domestic electricity are giving.
Truck brake slowly and then when you stop or take our foot off the gas pedal truck is working normally. This problem is only happening when the brake pedal is pressed and try hard braking.
I checked the oil and fuses
  • Posted 10 Feb 2014 16:55
  • By burhan_z
  • joined 10 Feb'14 - 1 message
  • istanbul, Turkey
Please check brake pedal switch maybe when you press brake pedal he activate,and when you release he does not turn back,and after short time do.
  • Posted 11 Feb 2014 08:24
  • By nemanja_k
  • serbia, Serbia
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
