Evaporator clean and ok?
Also check carburetor and choke plate condition... e.g. it's a common problem on Toyota LPG forklifts
Hi
How to check the valve EPR?
greets krzysztof
Hello
I mentioned shaft position sensor and camshaft position sensor for a new belt.
I checked the sensor wiring is ok
I checked the engine timing is ok
I checked the installation of lpg is ok
computer tested on the site is ok
there are no errors on your PC
the engine starts for 2 seconds and goes out
or shoots in the intake manifold as if he switched the ignition
I miss the idea of what might be causing damage
greets krzysztof's
Hello, Check for a broken wire to the sensor. It is a common fault.
In 9 bars of compression?
Is there a spark on spark plugs?
Try this:
Take out the spark plugs,inject few drops of motor oil in combustion space (to reduce piston rings clearance),turn back the spark plugs,make sure that fuel will be in compression chamber on few engine turns or better use start spray.
If engine starts,heat it to normal working temperature,stop it and try to start again.
If it starts normaly,stop it and let it to cool down.
If engine not starting after cooling down,problem is in compression...
