HYSTER H1.5XM
Hi Iv'e got no negative from distributor to coil. can not get a spark from coil and the distributor as pos & neg wire's going to the coil. Iv'e got pos feed from key switch to coil. Any suggestions welcome or manual please.
  • Posted 25 Jan 2014 01:47
  • Modified 25 Jan 2014 02:07 by poster
  • By richard_m
  • joined 11 Apr'13 - 110 messages
  • lancashire, United Kingdom
Thank you ian much appreciated
  • Posted 27 Jan 2014 05:37
  • By richard_m
just checked on truck today and the black/white is on terminal B and goes to coil positive terminal
the blue is on C and goes to coil negative
hope this helps
  • Posted 26 Jan 2014 05:01
  • By ian_h
  • joined 11 Sep'08 - 149 messages
  • United Kingdom
Thanks L1ftmech & Ian i also bought a new coil & module and can not get a spark the blue wire from the dizzy is pos and the b & w neg to the coil and the blue wire from the key switch goes to coil poss & there is the gas wire.
Ian do you know where the wires went on the module? neg was on B and pos was on C just to make sure some 1 before me as not put them the wrong way round, many thanks
  • Posted 25 Jan 2014 04:44
  • By richard_m
The positive feed to the coil is constant, the coil is always connected to the key switch output circuits.
However, the negative side of the coil is controlled by contact breaker points (if old school type distributor) or an ignition module (if modern style distributor.
You can only detect a negative circuit at the ignition coil when the breaker points, or ignition module are giving the coil a negative path to ground.
If the contact points or ignition module are functioning properly, you should be able to detect a "pulsing" negative path (using continuity tester) on the distributor wire while cranking the engine. The negative wire must be disconnected from the coil to do this test.
An alternative test for the same is to hold a test light to the negative side of coil (negative wire connected to the coil for this test) and crank the engine. If the test light dims (or goes dark) and brightens in a series of uniform pulses while cranking, it may be presumed that the distributor primary circuit is working right.
If the test light remains brightly lit throughout the test, there is a problem in the distributor primary circuit. The primary circuit of a distributor handles the task of controlling the negative side of the coil to produce, and time....the ignition spark.
The spark occurs when the primary circuit OPENS.
  • Posted 25 Jan 2014 03:55
  • Modified 25 Jan 2014 03:56 by poster
  • By L1ftmech
  • Tennessee, United States
hi Richard, I had the same problem last week.
you should have ignition feed to coil pos and the two wires from distributor go to pos & Neg terminals. you may also have another wire to coil pos that feeds gas unit.
try replacing the two wires from dist to coil. when I belled out wires they both seemed ok so I bought new distributor module & windings & wasted money!!
replaced wires and away she went!!
if you need the module and coil let me know, brand new and good price
  • Posted 25 Jan 2014 03:54
  • By ian_h
  • United Kingdom
SMV (Konecranes) 4632CC5
Taylor TX175
New - Sale & Hire
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
