Key Fobs and Keypads
Are there any guidelines or Legislation that stipulates how long the Key fob/pads should last until it automatically times outs once the operator dismounts their Fork Lift Truck?
  • Posted 24 Jan 2014 18:48
  • By as96
  • joined 15 Aug'12 - 4 messages
  • Oxfordshire, United Kingdom
So far every customer I've been to has asked for the time out period to be set to 5 minutes.
If the operator is to lazy to even press a button to switch the truck of & instead having it time out when leaving it parked up during break times / end of shift then that's an issue for there manager to deal with.
  • Posted 2 Mar 2014 00:52
  • By Forkingabout
  • england, United Kingdom
i'm not sure on legislation on this feature but in most cases i've seen when it comes to the truck timing out after the operator leaves the seat, it generally is set at a default time of around 30 seconds.
It is usually adjustable and can be shortened or lengthened depending on the desire of the owner. I'm pretty sure as part of the OPS (operator presence system) required to be implemented on machines now it just has to be present on the machine and operational.
There is alot of info to sift through in the OSHA and ANSI standard data and finding that particular reference is cumbersome. Maybe someone else already knows of this and can shed some better light on it. ;o)
  • Posted 2 Mar 2014 00:46
  • Modified 2 Mar 2014 00:47 by poster
Michel Denis Michel Denis
