sets code 1-4 [static return to off].anyone know of possible causes. allways does it when moving forward,while lowering.this is a palote jack. thanks kent
As swoop pointed out, check 'em.
Kent,
these machines have been known to have issues with the contactors and also with the estop.
I would look in those areas first
good luck
The mod/ser# EWP 45/A41 13694
Since mfg was not mentioned and assuming the unit has SB connectors i would check to see if the connector is actually connecting and not being pulled or pushed on by the battery cables when travelling. Brand and model would help bunches.
