Clark C25CL - Wrench Light Reset Procedure
Have a Clark C25CL with the wrench light illuminated. I'm assuming so correct me if I'm wrong this is a maintenance indicator. How does one reset this maintenance light. If its not the maintenance light, what condition does it describe? I have no operator manual and don't work on newer clark hardly ever. thanks
  • Posted 13 Jan 2014 13:02
  • By Howitt
  • joined 13 Feb'09 - 80 messages
hello Howitt.
Have you email adress?
best regards, Laci
  • Posted 14 Jan 2014 03:26
  • By LACI
  • joined 24 May'09 - 195 messages
  • Serbia
Found This:
Service Icon
LED will illuminate when pre-set service time is reached. When Led is On, the Preset Service time has been reached indicating that a pm is required. Refer to service manual for proper pm procedures Pre-set service time setting method - initialized by "Key On + FWD + F1 + F2", Service time display at hour meter. F1 is for upset, F2 is for down set. (with interval times of 50 hours) when the key switch is turned OFF, the pre-set service time setting is saved.
-1000 Will turn the light off permanently
  • Posted 13 Jan 2014 22:30
  • By Howitt
Morooka MFD20
TCM FD115-3
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
Morooka MFD20
TCM FD115-3
Morooka MFD20
TCM FD115-3
Board member, UKMHA
