Steinbock/Komatsu FB18 1E
I have got a fault code A10 on the BDI. Got no lift and no traction, tilt and sideshift OK. The truck has got a bosch control unit in.
  • Posted 2 Oct 2007 01:02
  • By Leon_W
  • Tyne & Wear, United Kingdom
With the A10 code, also check the contact pins in the multi plug that connects into the LT200, if the pins are corroded, or look like they have been spread where the connector has been un-plugged several times. This is a common code, it may be just a flat battery! Any more problems, let us know.
  • Posted 6 Oct 2007 21:48
  • By jason_t
  • joined 9 Feb'07 - 7 messages
  • Hampshire, United Kingdom
J-Tech Electronics Ltd
Hello
The system is locked off if the voltage is inadequate ( discharged battery)
Possible cause of the fault
1. The battery is discharged
2. The battery is loaded during an idle voltage measurement,e.g. by an additional unit such as a hydraulic system.
3. The battery is defective or has a cell short-circuit
Cheers
  • Posted 2 Oct 2007 04:36
  • By blackie
  • joined 9 Jul'06 - 52 messages
  • Gelderland, Netherlands
Linde C4230TL5
Enforcer FLBAXT25
