still over heating
can any one help me how to over come heating problemn of 4 cylinder diesel engine (S4S) we changed the piston rings , new thermostat, cylinder head facing , new head gasket, injectors calibrated , cooling fan running smoothly, new water pump i have tried al the posiblities still the engine is heating up till 95-100'C
  • Posted 28 Sep 2007 01:03
  • By allan_l
  • joined 24 Sep'07 - 32 messages
  • united arab emirates, United Arab Emirates
Pressure tested a bunch of rad caps,toss out 3 out of 4 for
fail of prsessure test.Kind of need to change these more often but Im as bad as any one looks good is good.
  • Posted 5 Oct 2007 08:30
  • By proshadetree
  • joined 23 Feb'06 - 484 messages
  • Tennessee, United States
This has probably been done also but I had similiar problem and after all the time and parts it was just the radiatoir cap.
Old one looked fine but I changed it and no more over heating problem.
  • Posted 5 Oct 2007 02:16
  • By Nash
  • joined 16 Aug'07 - 12 messages
I'm sure these have probably been looked at, but just in case.
1- Make sure the fan is correct for the machine. If the fan is of the wrong rotation it can not move air properly.
2- Makes sure the fan shroud is installed, positioned properly and it is correct for the machine.
3- Check for worn drive belts and pulleys. Worn belts and pulleys allow the belts to bottom out and slip under increased load.
4- Use a 50/50 mixture of water and anitfreeze to get the best heat transfer.
5- Verify that your gauge is reading correctly.
Hope this helps and Good Luck.
Tom
  • Posted 4 Oct 2007 22:12
  • By tom_w
  • joined 29 Jul'04 - 24 messages
  • Virginia, United States
this sounds good , their is not bleeding screw on the water pump ,
  • Posted 28 Sep 2007 20:01
  • By allan_l
Also test with a digital thermometer diffrent points to see where coolant isnt flowing IE head,radiator,water pump ect
  • Posted 28 Sep 2007 10:23
  • Modified 28 Sep 2007 19:28 by poster
  • By proshadetree
Have u tried a water flow test threw the rad ,,,,,,
ie ,, when u pore coolant in how quick does it flow
out,,, Did u pressure check the head.. is there
an coolant in the oil [ small bubbles ]
  • Posted 28 Sep 2007 03:19
  • By DAMO
  • joined 9 Jan'07 - 196 messages
  • DUBLIN, Ireland
