OM/Komatsu Reach throttle error
HI there
We have a customer with a OM pimesbo/Komatsu reach FB20RW1R/C1/PKKL
serial: F24519R0025
The original controller was damaged due to water ingress. The customer replaced the controller which when powered up came with error 'pot out of range'. Unfortunately the pot will not calibrate. The customer has tried with the pimesbo software, the win zapi software and even the komatsu/Zapi analyser.
They have also changed the full controller as they suspectedit might be a problem in the controller. Still the same error.
They then tried changing the foot pedal, which still comes up with pot out of range error and still will not allow calibration.
When testing the foot pedal on the handset it shows it changes from 0.3v up to 5v, but when they go into calibration mode, nothing changes the values all remain on 0.00v.
All the wires check back from the foot pedal to the unit ok also.
Any pointers would be of great help.
Regards
  • Posted 9 Dec 2013 22:11
  • By elektrodrive
  • joined 2 May'08 - 743 messages
enquiries@elektrodrive.co.uk
update:
it was the hydraulic lever pots faulty which was also preventing throttle calibration. once these were replaced it now allows calibration.
Thank you for all the assistance.
  • Posted 11 Dec 2013 20:44
  • By elektrodrive
Sorry the error was 'put out of range'.
Which according to the manual is related to hydraulic.
  • Posted 10 Dec 2013 07:15
  • By elektrodrive
Thank you for your comments and the information you have supplied. I was looking at the error list and it appears it could be pot out ofc range error related to the hydraulic lever pots and not the accelerator pot as I initially thought.
it also would not let me calibrate hydraulic.
we will try again this time focusing our attention on the hydraulic levers.
Will update once resolved.
Thanks once again
  • Posted 10 Dec 2013 07:12
  • By elektrodrive
If you can see that value from pedal on test min position MUST BE 0.5V and max is 5V
Please record like that it must to work
Are you sure that is drive pedal,what error you have on start up
  • Posted 10 Dec 2013 05:19
  • Modified 10 Dec 2013 05:32 by poster
  • By nemanja_k
  • serbia, Serbia
Hmm.. strange thing,
The communication between the analyser/pc-- truck is Ok?, did you try first to teach in the hydraulics pots??
Check mail
Regards
  • Posted 10 Dec 2013 05:11
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
Toyota launches three new stackers Columbus, IN, United States
Bobcat appoints new UK dealer Liverpool, United Kingdom
Mitsubishi FGE35AT
UN Forklift FB25N1LZ1
