Traction sensor troule
I have a 97 Nissan lift truck and it will not move,it is giving error code 524 T-C sensor and traction trouble, Where exactly is this sensor ? Any help would be greatly appreciated.
  • Posted 22 Nov 2013 07:44
  • By rutroooo
  • joined 22 Nov'13 - 6 messages
  • Arkansas, United States
Fault found. Was an open trailer hand brake.
  • Posted 25 May 2014 01:44
  • By vik_m
  • joined 17 May'14 - 3 messages
  • latvija, Latvia
NEED HELP!!!
http://s019.radikal.ru/i635/1405/02/d615bc5667b4.jpg
  • Posted 18 May 2014 21:27
  • Modified 18 May 2014 21:28 by poster
  • By vik_m
  • latvija, Latvia
NEED HELP!!!
Good day.Nissan P01/P02. FP01R 15U.What is trouble 530 and 512?
Please!!!
  • Posted 17 May 2014 17:34
  • Modified 18 May 2014 18:13 by poster
  • By vik_m
  • latvija, Latvia
NEED HELP!!!
No problem and thanks for letting us know what was ailing it.
  • Posted 16 Apr 2014 07:57
  • By RCAV8TOR
  • Alabama, United States
Hey just wanted to thank you, was exactly the problem you know your forklifts thanks again.
  • Posted 16 Apr 2014 02:09
  • By rutroooo
Thanks so much for that info.Will let you know if it works out.
  • Posted 25 Nov 2013 09:49
  • By rutroooo
This is a P01 or P02 truck. The traction current sensor is located on the bus bar at ther ceramic fuses. You may have 2 of them if the truck has chopper hydraulics. If you do then you can see if both are marked as same PN# and simply swap them to see if problem follows. Sometimes the ceramic fuse (275 amp)will blow and bridge inside. Most of the time i have seen these fail is when the bus bar gets hot. Check all your bus bars for indication of being hot and make sure all bus bar fasteners are tight. Worse case scenerio is print board. You should be able to press up or down arrow after code is shown and it will give you more info such as 530 or 531...... open or short over or under voltage info.
  • Posted 22 Nov 2013 10:30
  • By RCAV8TOR
model and serial number would be a great aide in getting information
  • Posted 22 Nov 2013 09:09
  • By meliftman
  • joined 31 Jan'12 - 209 messages
Liftman
Retired
Elberta, Al.
Tacoma, WA, United States
Orlando area, United States
Highland, IL, United States
