Hyster E1.50XL
Hi can any one help me with a service manual for this 1990 Hyster E3.50XL serial number C098U01940L or at least the part cover the power steering as i dont have any. it has two EV controllers a EV200 and a EV100 i believe the EV200 is the traction side and the EV100 is the pump side which seems to control the power steering. The problem i have is the contactor doesnt energise and if i manually push the contactor in the power steer pump works but the steering is still hard to turn any help would be great as iv not work on these machines before....
  • Posted 22 Nov 2013 02:55
  • Modified 22 Nov 2013 05:00 by poster
  • By powerlifter
  • joined 17 Mar'09 - 306 messages
  • united kingdom, United Kingdom
A good engineer is a helpful engineer
Cheers buddy il check it out..
  • Posted 22 Nov 2013 05:49
  • By powerlifter
Have a look under the steering covers its probably the same system.
Titus
  • Posted 22 Nov 2013 05:23
  • By Titus
  • joined 6 Jul'10 - 185 messages
HI Titus
Firstly thank you so much for your reply to my thread its much appreciated..
Im sorry mate i got the model wrong its a E3.50XL NOT E1.50XL
Do you have a manual on this machine if not any help would be great buddy..
  • Posted 22 Nov 2013 05:05
  • By powerlifter
I think this power steer system comprises of a p.s activator unit, an optical encoder, power steer contactor, and a pressure switch, optical encoder located just under steer wheel covers, activator unit located on bracket beside steering orbitrol unit, but from what you say that when ps contact pushed in the power steer motor runs it would sugest a lack of pressure being developed by pump or oil being returned to tank,
Test 1 system won't switch on,.With the key switch on short terminal 4 on activator to terminal 2 power steer contactor should run continually, this checks,
Line. 13 from activator to battery
Line3
Fuse 1
Key switch
Line10 power steer coil
Power steer coil
Contactor
Let me know how you get on. It dose say on my notes E/J 1.25 -3.00 XL
Regards Titus
  • Posted 22 Nov 2013 04:25
  • By Titus
Enforcer FD50T-MMA
Taylor TX330S
USD159,500
Enforcer FD50T-MMA
Taylor TX330S
USD159,500
