mitsi 4g33 engine
Had a truck in the shop last year,head gasket leaking,replaced head gasket, cyl head overhauled,run engine, burning oil,removed cylinder head and pan installed new rings, run engine, it smoked again, got cylinder head checked again, installed hastings rings, not to dad,sent back to the customer, truck came back in,oil leaks, perfect ill pull the engine, and rebore new pistons rings and head checked again, guess what burning oil any ideas. used two different machine shops.
  • Posted 29 Oct 2013 03:00
  • By towmotor
  • joined 19 Feb'07 - 360 messages
Less than 40000hrs on the unit,two cylinders oiled up, head back off and at the machine shop. No oil in lines from breather to intake manifold,50hours putt on engine last year.
  • Posted 30 Oct 2013 03:55
  • By towmotor
Are all the spark plugs oil fouled or just 1 or 2 cyls? If all fouled I would suspect a faulty breather system or baffle assy in valve cover.
Try running with all breather lines disconnected & see if smoking gets better/worse
  • Posted 29 Oct 2013 11:29
  • By bbforks
pcv system ok?
  • Posted 29 Oct 2013 06:28
  • By stam
I tried to use cheaper parts, caused me grief. I try to use good quality or OEM parts when it comes to engine overhaul. How many hours on the engine??? Did you flush and test rad,water pump, thermostat ect.. ?? 4g33 or 4g63
  • Posted 29 Oct 2013 05:56
  • By Prentice
Bobcat appoints new UK dealer Liverpool, United Kingdom
Tacoma, WA, United States
Highland, IL, United States
Dallas, TX or Lexington, KY, United States
Orlando area, United States
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
