I don't know why, but I have a Yale reach truck, model nr040ad [nl36te110], serial b815n0242v that does not seem to be exist in parts manuals or tvh. Does any one know why this series (nr040aD, serial series b815) does not seem to show up in tvh or other manuals? It has a made in USA to b56.1 sticker... I need to setup a new MIB and have no model setup. Does this model serial combo have a hyster equivalent?
I could also really use a pn for the pin-socket and housing of the dash display board (wire harness side, the smaller of the 2 white molex connectors ).
thanks for confirming that I am not the only one that does not see any "b815" NR/ad. The truck and controllers look a lot alike, same Curtis controller etc... just seems very strange to me to run across a truck that does not how up in IRMN or other sources. it would not be too bad, except the setup for the particular model.
maybe I will punt...
i've got info on a NR/AE series C815 but not the AD series B815.
i'm sure the MIB setup is the same but this is generation II so the settings may be different. It will tell you how to get in though but if you have any info already on other MIB's you probably already know how to access it.
