trouble codes
Victoria, Australia Hi everyone, can anyone help me with crown sp3000 stockpicker error codes, ive got a unit the wont key on and spanner light comes on only being able to access error code 16 as last code shown, any help would be great thank you
  • Posted 24 Oct 2013 08:42
  • By thetine_m
  • joined 24 Oct'13 - 3 messages
  • Victoria, Australia
Cheers Matty
hi
I want to ask the error esr 843 4000 crown unit was what
thank you
  • Posted 12 Nov 2013 06:17
  • By ario_alif
  • joined 12 Nov'13 - 36 messages
  • east java, Indonesia
This status code is displayed when the battery volts are greater than 2.40 volts
per cell at initial start up.
Symptom: Forward or reverse contactor will not energize.
Possible Cause
- Battery overcharged or incorrect battery installed.
Check battery state-of-charge and take corrective action if necessary.
- Incorrect control card setting.
If control card was just installed, make certain Function 15 of control card tune up is set correctly. Refer to tune up
section (M4.2 in truck Service Manual) for correct value.
  • Posted 27 Oct 2013 12:23
  • By Truck_Tech
  • United States
16 is either battery too flat or overcharged
if overcharged raise and lower several times then disconnect battery for 30 seconds and try again
if flat place on charge
last name doesn't start with d and end in n does it
  • Posted 25 Oct 2013 19:26
  • Modified 25 Oct 2013 19:27 by poster
  • By crownie
