hyster H90XMS K005v05845A
1st start in morning, truck idles fast for 5 minutes then drops to normal idle. Durning the day, if the truck is shut off for 5-15 minutes, or longer, again, the fast idle has to run its course before lowering to normal.
The issue is intermittened, not always happening after 1st start, any ideas?
  • Posted 22 Oct 2013 04:18
  • By 7777
i sent you a couple diagrams showing the component and where it is located :o)
  • Posted 28 Oct 2013 00:33
Thank you Swoop, what does the IAC look like, where is it located?
  • Posted 27 Oct 2013 22:28
  • By 7777
sounds like a problem with the IAC valve (Idle Air Control)
remove and clean it first
if that does not help you may have to replace it
  • Posted 26 Oct 2013 22:36
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
Mitsubishi FGE35AT
UN Forklift FBR25NQC3
Tacoma, WA, United States
Orlando area, United States
Highland, IL, United States
Dallas, TX or Lexington, KY, United States
