Yale GLP060VXNGSE
I have an ongoing issue with this machine. Unit has only 1600 hrs of use & the regulator has been replaced twice as have the fuel injectors. It's lpg fueled & has the GM 2400 vortec engine. Now the unit is acting up again- having symptoms of having 2 fuel injectors being "sticky"- they stick open- causing the machine to miss on those cylinders.
Customer has gotten a certificate from his lpg supplier that he is purchasing HD-5 fuel- the fuel is from Sunoco.
I've suggested an in-line thermostat to the lpg regulator & cooling vents in the hood assy to cool the unit off, but he resists- saying that the factory would have installed such items if they were necessary.
Does anyone know of any independent testing labs that can confirm the fuel is in fact HD-5? Also- does anyone know of any injector cleaning product that can be added to the fuel? Lastly- does anyone know of a source to have the lpg injectors cleaned? At $170 each- they start to get expensive- Thanks for your help
  • Posted 18 Oct 2013 23:15
  • Modified 18 Oct 2013 23:16 by poster
  • By bbforks
Ed- correct me if I'm wrong- this is how I diagnose ign/ fuel injector issues:
engine has miss- determine which cyl is missing.Then swap ignition wires to see if miss stays on this cyl or follows wire. If stays on this cyl, then swap spark plugs & do the same test again. If still stays on this cyl, then swap fuel injector & test again.
This is now the 3rd time I've had a service call for this unit, done the above procedure & have the miss follow the injector. The first time it happened, I was given permission to replace all 4 injectors. Unit ran good for about 400 hrs then began to miss again. The second time around, I was only allowed to replace the faulty injector. Within a month each of the remaining injectors needed to be replaced, 1 at a time at the customers request. That was about 500 hrs ago.
  • Posted 20 Oct 2013 11:44
  • By bbforks
how sure are you it is a fuel problem?
I have recently seen a truck with the same motor, where the symptoms were the same as yours, and it turned out to be one of the coils failing.
  • Posted 20 Oct 2013 04:39
  • Modified 20 Oct 2013 04:39 by poster
Anyone?.....
  • Posted 20 Oct 2013 01:19
  • By bbforks
Komatsu FD25T17
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
Toyota launches three new stackers Columbus, IN, United States
