Jungheinrich EFG 20 AC 2003 service maintenance light
Hi all , anyone have the code for set the service maintenance light of in the display of this truck ? i need the 4 code numbers for the display settings
Regards
  • Posted 16 Oct 2013 06:02
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
Hi Diesel123
Do you think removing the battery from the display unit will reset the password back to factory settings aswell.
JH have changed the password on this one I have.
  • Posted 28 Feb 2014 01:12
  • By fred_t
  • joined 27 Feb'14 - 15 messages
  • london, United Kingdom
HI all
EFG 535 MP
Helps to remove the battery display?
Or where to buy sn 50125023 Programmer, hand held
  • Posted 25 Nov 2013 05:45
  • By geroj
  • joined 21 Feb'10 - 262 messages
  • Krivan, Slovakia
Hi Piotr , yes i know i can used can-usb but they software program jungheinrich i have not.
Older versions of display you van take the bridge on the print behind the display for reset the truck to fabric settings , this displays have not and is a newer version.
the local dealer have change the setting now.
  • Posted 25 Nov 2013 03:45
  • By gc_d
Regards gc_d
I used converter can-usb what buy in market and normally change all parameters in jh truck
  • Posted 24 Nov 2013 20:03
  • By piotr_b
  • joined 3 Jun'09 - 41 messages
  • mazowieckie, Poland
Unscrew the dash and remove the small "watch type" battery for 30 seconds. Refit and it should have turned the light out.
  • Posted 27 Oct 2013 07:59
  • By diesel123
  • joined 10 Jun'09 - 20 messages
  • antrim, United Kingdom
should be 1234 need to access first with buttons space flashes then enter 1 move to next space 2 etc then enter think this is the boss , komatsu version also plays tunes but cant remember how to set : )
  • Posted 25 Oct 2013 06:54
  • By trevb
  • joined 10 Jan'12 - 157 messages
  • avon, United Kingdom
1234 or 4321 when light light service key.
If it flashes only helps PC.
That is my experience.
  • Posted 24 Oct 2013 12:28
  • By geroj
  • Krivan, Slovakia
is this the display under the steer wheel with hour meter then eggtimer snail buttons etc on rhs
  • Posted 24 Oct 2013 07:38
  • By trevb
  • By trevb
I'm not sure, you can do it without a laptop/JUDIT. I've checked the servicemanual and it tells nothing :-(
Regards, Max
  • Posted 17 Oct 2013 05:04
  • By Fittermax
  • joined 17 Jul'08 - 171 messages
  • Denmark
Thank's for helping. Contact d-b-a@mail.com
P i s s Work, gone fishing
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
Tacoma, WA, United States
Dallas, TX or Lexington, KY, United States
Orlando area, United States
Highland, IL, United States
