codes - 2b - 6q - f4
I hava a raymond with codes - 2b - 6q - f4 - They are sparatic and its usually fine then it will stop. The operator also said that it lost its plugging ability but i have not been able to confirm it. It works fine for me. The unit was really dusty and i blew it out. The ignition switch had a couple loose wires and smelled burnt so I replaced wire connectors and cleaned out switch and tested it. Its tests ok but I still think its the problem or part of the problem. Can someone tell me what the codes are?
Thanks!
  • Posted 29 Jul 2013 14:32
  • By bishop
  • joined 29 Jul'13 - 2 messages
  • Arizona, United States
2B - Drive shutdown - main transistor current sensor out of range
FG - Check battery - vehicle manager +12vdc out of range.
Check battery voltage first and verify battery is good. Check Key/EPO circuits as mentioned above. Check 12 volts at jps2-1 and jps2-2 in parallel on the VM connector. If no 12 volts id be looking for a short or a component pulling down the 12v. let us know if its there or not.
  • Posted 29 Mar 2017 10:28
  • By stam
I have a 2B FG code saying return joystick to neutral and hit enter. The joystick is in neutral and I hit enter but nada.
Any clues?
  • Posted 28 Feb 2017 01:39
  • By buylowsellhigh
  • joined 23 Feb'17 - 2 messages
Thanks for the feedback! that makes sense. I figured as much and put in a temporary switch a couple days ago and have had no futher problems. I am now just waiting on a new key switch. I really appreciate the reply!
  • Posted 2 Aug 2013 11:27
  • By bishop
Here's the codes descriptions :
-2B : Drive shutdown (main transistor current sensor out-of-range)
-6Q : Shutdown (Lift circuit detected shorted)
-F4 : Shutdown ( Computer Card COP Timeout)
Lift won't lift/travel when thoses codes appears that can explain the lost plugging.
A resistive key switch or loose wires at key switch can cause thoses problems.
  • Posted 2 Aug 2013 06:56
  • By ted_h
  • joined 16 Jul'13 - 2 messages
  • Quebec, Canada
Oxford Ct, United States
Tusk 500PGH14
Terberg YT223
Tusk 500PGH14
Terberg YT223
