Nissan - Hitachi drive control
Can someone please help with drive fault on Hitachi drive control - very slow creep speed then jumps into bypas speed ? - both directions the same, Lift works ok but no smooth drive at speed.
  • Posted 27 Jul 2013 00:58
  • By Reddog
  • joined 23 Feb'09 - 58 messages
  • Wrexham, United Kingdom
Thank you for the advise I will try what you have said but the battery is not 100% so will need to sort that first.hope you can assist further if the above dosnt't resolve the problem.The battery is 36V - 18 cells the logic cards shows 36/48 volt options.
  • Posted 2 Aug 2013 00:39
  • By Reddog
Reddog;
Check capacitor's charge up rate and it's charge voltage when the battery is just connected up to the truck. Meter pos on capacitor's positive terminal and the meter negative on the truck's negative terminal in the power distribution panel. You should see no more then 2/3 battery voltage and the charge up rate (RC time constant) will occure. An example would be if the source voltage were 10 volts, the resistance is 10 k ohms and the capcitance is 50 micro F, the RC time constant is 0-5 seconds. After 1/2 second, the capacitor will be charged up to 63% of 10 volts, or 6-3 volts. After another 1/2 second the capcitor will charge up to another 63% of the remaining voltage of 3.7 volts, leaving the capacitor about 86% charged and so on. Not having the truck's battery voltage prevents me from more detailed information.
  • Posted 2 Aug 2013 00:06
  • By MEngr
  • Missouri, United States
I thought that may be the case - the appears to be a few burn marks on the buzz link bars on contactors were possibly the logic card has shorted on ? - may be cheaper to retrofit ?
  • Posted 1 Aug 2013 17:12
  • By Reddog
I would guess a bad logic card.
  • Posted 1 Aug 2013 03:03
  • By mike_v
  • joined 1 Jul'10 - 190 messages
  • Illinois, United States
mike_retired
Nissan 50 - D371898
No codes present ? - I believe it was actually imported from American so you may recognise the model ? - it just seems to have no torque ? - until it hits bypass contactor ?
  • Posted 29 Jul 2013 17:47
  • By Reddog
Model AND Serial number would be a help.....plus any codes that are showing up on the display.....
  • Posted 27 Jul 2013 01:44
  • By kevin_t
In 1923, French tennis player René Lacoste was promised a crocodile leather suitcase by his captain if he won his next match. He lost the match but won the nickname "the crocodile" which he had sown onto his tennis attire. Ten years later he launched the first polo shirt and Lacoste, the first brand to feature a logo on its clothing.
October 15-16, 2025 - Las Vegas, United States
November 13-14, 2025 - Berlin, Germany
Mitsubishi FD200
UN Forklift FB25N1LZ1
Atlanta Savannah Orlando Tampa Jacksonville West Palm, United States
Sioux Falls, SD, United States
