No forward or reverse
When u turn machine on and go to forwards or reverse the contacts pull in then machine starts to barely move then it bangs and contacts release. U have to turn off to get it to do it again if u don't contacts won't pull in.
  • Posted 25 Jul 2013 08:12
  • By Simonater
  • joined 25 Jul'13 - 3 messages
  • British Columbia, Canada
Capacitor bad. New one in and up and running.
  • Posted 26 Jul 2013 04:09
  • By Simonater
sorry i read turn and went down the wrong path
if you have an LX handset you can plug into the card and get current fault code
otherwise test each component
capacitor usually tests accurately
  • Posted 25 Jul 2013 15:25
  • By crownie
  • Victoria, Australia
Already checked those and every other switch known to man. I'm thinking it could be a bad capacitor. Changing it out tomorrow with a spare.
  • Posted 25 Jul 2013 09:43
  • By Simonater
steer switches underneath truck are not turning off inside motor when making a turn
the switches are under truck either side of steer race 180 degrees across race from each other
check arms on swithes are not bent or fallen off
  • Posted 25 Jul 2013 09:17
  • By crownie
Sue Tomic Sue Tomic
Kalmar DRF450-70C5XS
JCB 533-105
ROYPOW
